Yep. I believe if you have a towing vehicle with no stated maximum towing weight (not sure on the date for this but I know it applies to S2 land rovers but not S3 so must be post-1973) then simple train weight applies, so as long as you have appropriate braking arrangements you can tow over 5000kg. Not sure I would want to, but I know people who have done this with boats, I believe carrying written confirmation of legality.
Alec
No towing limit / GTW = no towing allowed at all.
Landrovers were rated to 4000kg max with air brakes.
Ask landrover. They sold a lot of cars with weight plates with no GTW stamped on them for sale overseas. Some were re imported & can now not tow at all.
  • Replies 182
Most traffic officers go by gmw not what it actually weighs so I would be careful if your towing a trailer with gmw over 750kg.
This coming from experience as now I have a b+e
Sent from my LG-H850 using Tapatalk
For LICENCE reasons they use PLATED weights.
For Construction & Use regs they use real weights.
So IF you answer the 3 questions & say no to at least one of them (and are not over loaded) you have nothing to fear re your LICENCE.
People mix up Licences, C&U & makers specs / recommendations.
All have different rules re how they are enforced.
That is true however the vehicle would have to be rated for it too. From memory the only ones were landrovers rated to 4000kg.
Now all BE is 3500kg as I found out when I looked at my licence using the view a licence service.
I am not sure if this is a mistake or a retrospective change.
Yes the Land Rover sprang to mind.
I too have checked and my BE is also now restricted to trailer MAM of 3500, it's a bit sneaky I wonder how to query it.
I am already on it.
My money is on a low grade tech sorting the website made a few short cuts with the coding or checking the specs thinking BE was BE for everyone.
Alec
This man is psychic!:biggrin:
Yes I was thinking about Land Rover, in particular the early ones. To be honest I don't know when they started putting towing info on their chassis plates but even on the Series III it was a 'recommended' 2 ton. There is no towing information to be found for the Series II model but some adamantly believe (discussions can become quite heated) that the Series III figure also applies to the Series II. I'm one of those who will use a 3500kg trailer if needed behind mine . . . . and I passed my test before it started getting complicated!
Basically who ever deals with the licenses will strip you of anything they can.
I renewed my license last year and gained a towing restriction of 8250kg. I even had the evidence prior to the change of address and printed the sheets off and sent it I. With the forms for renewal/address change.
They claimed they didn't know what I was on about and. That restrictions in 1997 blah blah blah...
I told them to check the actual restrictions from 1992 when I passed. The answer came back as in 1997... blah blah blah.
I escalated it twice and even had a transport consultant advice me. Still the same answer. I figured I was talking to a brick wall .
Not psychic - just a good guess from your User ID :001_smile:
I have also read the heated arguments on SII forums. Not sure which way it would go but I would certainly be prepared to go to 4000kg on air brakes, bearing in mind this would be towing sawlogs slowly on back roads, so not actually any worse than common practice on agricultural registrations.
Alec
My son's mother in law had the opposite happen. Got her licence back with entitlement to drive everything under the sun. She used it to hire a dirty great removals lorry when she moved house, she'd never been near a lorry before!
I've heard that if you have any issues with your licence/entitlements you have to be able to quote date, time and place when you took your test. Unsurprisingly not many people can.
Edit. agg221, I thought that name was vaguely familiar. It's a small world, even smaller now. Cheers.
Edited by SWB58
