Which saw for these requirements?
GJohn86
Grind the fins explain to the dutch guy stubby , what do you mean .
Sent from my iPad using Arbtalk
If you remove the transfer covers you will see on the inside that there is a fin on each . A kind of restriction . If you carefully remove them with , say a Dremmel or similar it then becomes identical to the 372Xtorque saw only a few quid less in price . Ridicules I know but there it is .
Is there a way too get more power out a 550 xp / 562xp
As you know i live in Holland . I mean a cheap way too do it by your self . Just a little more power saws are brand new .
Send it to spud , check out the chainsaw section of the forum he has a porting thread. He did a port job timing mod and popped up piston (Burrell did the milling) and muffler mod on a 560 for me ... the saw is ridiculous in soft Wöod!
An old husky 288 that will run a 32" for milling and 20"for fire wood but they hold there money so will be around 250-400
Or an old 266? They can be picked up a lot cheaper would probably pull a 32" on skip.. very torquey saw though.
Try and go for a late model plastic chain brake handle version of both saws if you do.
