casto
MB trac.... what's your opinion?
Evening all
I'm thinking of starting the search for an mb trac to replace one of my u900's. I just wanted to see what people's experiences are of them. I've heard a lot of good things about them.
I'd be looking for a 6 pot so 1000? up to a 1500.
Thanks in advance :001_smile:
Share this post
Link to post
A plant hire company I worked for in 1995/6 had an MB1500.
It was B reg iirc so around 1985 vintage ,we used to use it with a 3 axle low loader trailer for moving excavators around locally , used to pull a 20ton machine around easily.
We also used a 15 ton dump trailer as well , I remember that there was some problem with the gearbox and this was removed and sent to Mercedes for repair . When it was refitted I found that it had gained an extra gear, apparently they all had this high speed top gear but it was blanked off unless specified by the original purchaser , this turned it into a flying machine with air brakes thank goodness!
I am not sure if they all had reverse drive capability but this one had the seat and steering wheel with dash etc on a turntable affair that could be turned around in opposite directions,leaving the gear levers where they were. All in All a good tractor but very cumbersome and primitive by todays standards.:001_smile:
Martin.
Share this post
Link to post
Very good machines. Tin work can rot away if they have lived outside or had a rough life.
Like all 80s tractors they look a little dated on the inside. Like unimogs merc still make all the spares.
Share this post
Link to post
Thanks Martin!
As far as I know, the bigger mogs had a blanked off gear, not sure what speed that would take one up to?! A reverse drive sounds like something useful as well!
One of the reasons I thought about having an mb is there 40k boxes and front suspension making them more comfy on the road? I also like the older gear, no electrics to go wrong
Share this post
Link to post
As long as trac's are a bit comfier and have a radio I don't mind too much. They sound like the massy 698t I borrow, :lol:
Share this post
Link to post
The 1500 used to ride well on the road ,not sure how fast but the tyres used to hum with the extra gear!
I never really used the machine for proper tractor work mainly transport duties. The reverse drive would be good on a mulcher I would imagine.
The cab only had one door and you had to be mindful of this in tight spaces.:001_smile:
Share this post
Link to post
Can't beat a good tyre hum:thumbup:
Yes, I can see that would be great with a mulcher on or general mowing works.
As much as I'd love a brand new valtra or fendt my little budget won't stretch to one of those and the mb trac seems to be a good old style machine that could almost keep up with a modern rig?
Has anyone used one on more of the agricultural side? Not just hauling?
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
