i dont know if they exist????and if they dont this will be the first:thumbup:
(its not mine) its his new toy...
but its getting converted into a decent log splitter...
should be a good machine:thumbup1:
Cool, Keep us posted :thumbup::001_cool:
  • Replies 46
Neat idea Andy, i think that could be a very good sollution! Also with regards to the slider, is steel on steel good enough or would a nylon insert be a better idea?
Cheers
Dave.
Alright Dave . We have a brass wear plate as this is a softer metal .
Its a drill, a big one for making holes in rock faces and suchlike.
They “grout” fill them to stabilise the structure or you can put explosive compound in and have much more fun.
Sounds like my kinda job :thumbup:
How about using a small slew ring off a 1/1.5t mini digger. You could mount a heavy plate on top and it should easily take the loads. You should be able to pick a second hand one up from a plant breakers.
Cheers for the suggestions! I've decided to put 20 bearings underneath as well as a bit of box section in the middle to stop any bend in the bottom, this is the cheap option as I got 10 bearings for £7.50 :D . In theory the bearings will easily take the load, just have to see how/if the plate bends under the pressure! The splitter is half built, and weighs quite a bit already! I'll put some pics on soon!
  • 4 weeks later...
Hi, as promised here are some pics of my log splitter at the moment, still got a bit of work to do on it, but its not too far off! :thumbup1:
I'll put some on when its working and painted up!
Cheers Dave.
Well.... the cylinder is the most costly thing, but a control valve is about £60, pipes with all the connectors is about £80, the bearings were £7.50 for 10, the steel propably cost me £100/150 but I did have some of it already and quite a bit came from the scrapyard! if you can get your hands on the hydraulics then thats the most expensive part of the log splitter! Hope that helps! How big is the cylinder? :D
