Mills in Ipswich
cornish chough
I have an Autotrek, but that's about 39" max width of cut, rather depends whether you just want all waney edge as opposed to 1 SE?
Shrublands sawmill has a tom sawyer (I think ) just north of Ipswich
RH Wilden has a biggish stenner but they are out Garboldisham way.
Peter Clarke @ Timba Haul has a big Forrestor ( up to 60") but he's north of Norwich and not sure its still a runner.
Tim
Someone with a big Alaskan. Mine might do 4ft.
For a single log with a milling spec of reasonable thickness boards that might work out most cost effective. 4' with an 090 is OK, although if there is more to do it's worth going to a double powerhead set-up (also possible).
I have milled in Ipswich before - http://arbtalk.co.uk/forum/alaskan-mill/49031-need-some-milling-done-near-ipswich.html and could do it if required.
Alec
