Wire core llanyard
OsbornesGSltd
At what girth would you start using a wire core llanyard, and do they work with petzl grillons? thanks
There is no pre determined girth point where a wirecore lanyard use is recommended as its really up to the climber to determine when its use is appropriate.
I know some guys who never use wirecore lanyards,ive rarely used mine.The point of it is its more rigid therefore easier to flip,so with that in mind id say if your having problems spiking up a stem as you cant flip your lanyard then a wirecore would be ideal.
As for the grillion as far as im aware thats a petzl lanyard with a grigri on it,if its the grigri you mean,which is just a fancy rope grab,then id think it would work fine on a flipline but the grigri that comes with the grillion is only safety rated if used on the petzl grillion rope.
Just petzl covering there arse incase anything goes tits up
More like Petzl insisting that you buy their expensive replacement lanyard rope. It's the same with the Zillon.
If they were to be honest, it has little to do with the actual likelihood of an alternative rope brand failing.
Again, it's how the product achieved its CE mark and EN numbers, as a combined unit. Teufelberger pretty much did the same thing with the CE lanyard.
Totally agree.
