  • Replies 20
If you use this type of cutter make a jig up out of a bit of ply/mdf to stop it skittering all over the place 👍
I've never had that problem, but I'll keep it in mind.
Guessing you use a pillar drill? Back in my past life as a joiner you would just use a battery drill if you had to [emoji33][emoji23]
I did a load for a mate once.
Forstner works well but its slow compared to a hole saw that only cuts a fraction of the material.
Simply drill and pop the plug out
A hole saw would drill right through, then the tea light would fall out of the bottom.
