Had this happen to me once. Used a dremel to cut a slot & unscrewed it with a screw driver.
I now replace the bolts at every blade change, save a lot of grief.
same here mate, new bolts each time, saves time and money in the longrun :thumbup1:
  • Replies 44
if you clean the heads out properly,use copper grease & dont over tighten them they will last a a couple of dozern changes before they need bining :001_rolleyes:
Sounds expensive
Is it though?
Compare the ability to perform a blade change with a minimum of fuss and bother and a minimum of time, to breaking out diverse grinders, drills cutting tools and the like where you will end up with a trashed fastener that you will have to replace anyway.
Workshop time is about £35.00 per hour, you can probably buy a whole box of fasteners for the cost of freeing one knackered fastener
With a new fastener you will also be able to set the torque properly and lets face it, the cost of the fasteners isn't exactly astronomical.
Sounds expensive
What's a couple of quid for six bolts to save messing about?? Surely u can't be that tight:)
Hodge
If you clean the torx out properly before hand then they are fine for at least 6 changes. I spray mine with wd40 or something similar to loosen the dirt. I then clean out the torx with an old chainsaw file pointy end. The time I have had trouble was when tightening them once, I was able to get it out no bother. I now change the bolts at the first sign of wear.
Hodge
