You are welcome :)
The above needs doing whenever the brakes are getting to not work.
The more you turn the pto on/off and use the power steering the more often it needs doing.
Cheers Peasgood, we'll give that a go.
Actually need a new drop arm for the left hand side as the fork has snapped on one side and there's a bit been welded higher up.
I have one of those, brilliant little tractors, the brakes probably only need bled, there is a bleed nipple on each side at the rear on the top of the axle tubes!
OOPS bit late with the advice!!
