Electric grease gun?
MattyF
They're brilliant, you can actually grease without needing a third hand. We just got a new draper for £100 from our dealer after my old one got smashed. As long as you remember to keep the battery charged they've got plenty of pressure and last over a cartridge.
If anything I think they have more pressure than a manual because you can get them stuck on a blocked nipple.
Milwaukee do one to fit there batterys if your looking for other tools as well
But tbh i prefer a pistol grip grease gun with extra long hose
Never runs out of battery smaller and the battery ones are very easy to over grease bearings
If you want a third hand whilst greasing simply and cheaply, a lot of great reviews from guys using the 'G Coupler' connector on their ordinary grease gun setups.
I went over to the Fuchs 'Reiner' system and never a greasy hand or wasted spot of grease since. Not the cheapest cartridges, but they hold more and you never waste any so that pulls a bit back. These come with top quality hose and connector that never seemingly needs holding on.
Eddie.
Cannot comment on "leccie" grease gun but from experience on heavy construction plant we always used the hexagon nipples & the slide/lock on ends on the grease gun extensions it's then a problem free 1 hand operation as the need to hold/ make seal between gun & nipple is no longer required The guns we used were air operated with adjustable pressure
we use a one handed fuchs screw in cartridge one, seems good one hand to pump one to hold nozzle.
much better than the traditional ones!( always ended up with more grease over me than anything else :) )
