Husqvarna 365 special
avio
I've recently got an old 365 Special. Compared to my everyday Echo 420 it's bigger, heavier, and altogether less nimble. But for bigger stuff - I'm using a 20" bar - it's absolutely excellent.
I just cut firewood with mine, so it's more of a hobbyist point of view than that of a working professional. Seems more than rugged enough, though possibly a bit heavy if you're using it all day every day.
Hi
365 is a nice saw, agree with Stubbys comment, also it can be modified to a 372 by grinding the fins from the transfer covers, the only difference (AFAIK) is the 372 has slightly larger piston & bore.
There are two versions: 365 special (earlier) & 365 Xtorq being 65 & 70 cc respectively - both are excellent saws. No autotune in the 365xt so no expensive electronics.
Pulls a 20" bar very well, havnt tried mine on larger bars but perhaps consider skip chain if used with a 28".
N
Can you turn a special into a 372, or just the newer x torque?
Quite a few how to's on the tube, like this which I think explains it quite well
or get Spud to do it for you
N
I've got a special, its immense, loads of power, cuts like a dream. Favourite saw. Get it.
me too. mine is years old but mint. it's also running a big bore kit which i tink is 72 or 75cc and muff modded. It's wears a 24'' c&b.
Hi
.... N
That's only possible with the newer X-torq ones, that has the same basic 71cc cylinder as the 372xp X-torq.
