Or the tree kit neck lanyard , personally I found a neck tether far better for a RW and less restrictive although due to the weight of the devices like the hitch hiker and bulldog bone better off a Chest harness but every one is different and not going to like the same two things.
  • Replies 345
Get some of the treemotionelastic and slide over a cover of another rope. Then tie two fisherman a knots in each end of the elastic and clip in a small bina.
Or
Take a Lyon tape sling and out an overhand knot in the middle. Place over shoulders like a rucksack and clip a bina to pull the loops together. Use as a chest harness.
Both cheap and easy to set up.
Or
TM elastic, through TM gear tubing, through Marlow Boa cover with the core removed.
Glad I finally found a use for that horrible cord.
[ATTACH]206985[/ATTACH]
Nicely done!
Or
Thanks rich, loving the profile pic btw
If you kept the tool accessary spares off a tree motion they are perfect !
thanks ! ended up using the elastic from an old tourniquet and the connector ring from an old tool strop. Definitely scope for loosing teeth if it pings loose, so will find something rigid to go over the top of it...
