Hi Matt,
ATV or Quad won't be any good in this area. I tried it a few years ago and found the lack of weight meant traction is a problem over 250kg, and forget hills both up and down.
I settled on this in the end all in about £30k, it won't make you a millionaire and is not a stand alone business but working alongside other crews and resources it can make a difference on certain jobs.
Hope this information helps.
Was that your outfit working on the NT land at Holford recently?
  • Replies 30
Wendelspanswick, yes we were there doing bits and bobs for NT. Weather was not on our side for most of it but it looks good now.
CHC I can't get your attachment. I'm in suffolk and you..?
ImageUploadedByArbtalk1454567044.393049.jpg.1f95ca4e00d4ca832615074b9b2b34c3.jpg hope that works I'm in Suffolk to more around the Essex Suffolk border really
The problem I find is moving it from site to site as its to long to go on a trailer as one unit but if you load the fowarder trailer up first you can't in load it the other end unless there is a loader or some sort, and same the other way other then that good machine
[ATTACH]198102[/ATTACH] hope that works I'm in Suffolk to more around the Essex Suffolk border really
I'm the other side up on suffolk/ Norfolk border.
I either move site with two trailers which can be a pain but ok if it's for a good amount of work or a friendly farmer has moved it with his tractor and low loader trailer.
Matt.
Of your on the quantocks, well west somerset area! You know as well as me there is a distinct lack of flat woodland, and the end of the day you need something which is effective, yet safe!
That eBay dumper looks good, but I was thinking a 2.5 tonner so it could be trailered?
I own the woodland and meadows on the right as you go up to the pond, I had a nosey at your kit while it was parked up and I was very impressed, quality machinery!
i have run a Alstor now for 6yrs and wouldn't be without one , easily copes with all terrain and a light foot print .
the new 821 is a dream to drive and does 25 to 40 tons a day depending on extraction distances etc i is made for the job and i have never ran out of work
