Starting to get a bit fed up with the weather too- can just about get into fields to do fencing jobs but usually by the time the job is done its looking like a quagmire:thumbdown: Not only that but everything takes so much longer when your working in welly deep mud most of the time.
Always thinking of other ways to earn money with out having to rely on te weather.....
Hi MATTHEW Need a hovercraft down here mate oh wait is it's very bad thanks John
  • Replies 108
One of our contractor friends said they were trying to put off doing a big fencing job because the ground was so soft.... but the ground never firmed up and Glastir were insisting that the works were done within the contracted time frame.
So they got on with it but straining the wires was a nightmare (with the tensioning pulling the posts) and also made a huge mess of the fields.
cheers, Steve
cheers, Steve
Hi Steve it will make mess of field I all so seen one chap painting his house round in the rain mad thanks Jon
Thanks for "Arbtalk",as at least one can see that there is usually someone having the same problems as oneself,if not worse.
Out of interest "The Farming Forum" is another good forum especially for machinery related problems.
Hi mate it a joke here we must of 25)50mm of rain in the last 24hrs thanks Jon
I should think it is hellish all over the U.K today. Does your yard drain away ok Jon on the Mendips or are you in a valley, still hellish whatever!!!
Hi MATE we have tons of run off were in the process of building a new yard up as we were renting one time thanks Jon
We had a flood that washed logs out of 1 building! Logs put away last summer mostly dry, but finding damp patches now as we get near back of our hard wood shed, this has been worse other years, but always depressing! Try and solve the problem ever year, but never quite get it right! Snow, rain, condensation etc. Does help if all logs are really dry when put under cover, even if raining while processing, will cause the black/damp patches. Barn open all sides, so plenty of ventilation.
