My 395xp started cutting curves and despite some really good filing, it still cut a curve. 36" bar.
Then Dave (top cutting chap), noticed that there were 'burrs' on the bottom of every tie-strap/link.
What would cause this? Was the chain too tight? Are the insides of the rails worn?
Neither of us have seen this before. I forgot to take a photo but can get one tomorrow, although I'll forget.
Thanks for reading.
what condition is your drive sprocket in?
worn sprocket will rapidly wear a chain to match...
failing that incorrect chain tension, or lubrication issue will cause rapid wear
Sprocket is ok, I think but I will check.
Chain was a bit tight during the last tree.
Lub was good. Correct oil and oiler turned right up and not blocked.
It is the correct bar for the chain.
What the hell is a powermate? A big bloke drinking in the pub?
Yes the burrs are on both sides.
Oregon name for drive sprocket .
Lol!
Yes it appears to be ok.
Is it a sprocket or a rim?
I discarded sprockets as soon as the drive link bottomed out, telltale is a bright spot at the bottom of the sprocket, rims tended to disintegrate as a sign of wear.
