Just after some advice, for the past 8 years I have cut and split a small amount of logs each year for myself and some to sell. Last year I had use of a hycrack pto splitter but otherwise all done with saw and axe. I now have a growing pile of wood. It's all arb arisings so varying sizes and shapes. I am considering how to process it more efficiently. I like the look of the riko wp36 road tow and I think I could get some funding towards a processor but would I be more efficient just getting a saw bench and hydraulic splitter? Any experience gratefully received!
  • Replies 31
If its all odds & sods then processors lose their advantage.
You spend more time feeding it than working it.
If the bits are short then the lifters on the WP wont work so you end up manually lifting it all.
Pretty much in the same boat as you ,except most af my wood comes from orchards at the minute.
I bought a Thor Mignon , second hand from the Bay.
It really makes life much easier for me and is versatile in that it will do billets and rings.
Sent from my SM-G900F using Arbtalk mobile app
I am still mulling buying a 2nd hand processor, for clean Sitka, I got the impression this was the time of year, post winter, individuals or firms changed machines.
Probably dealing with Wilsons or Caladonian.
Except I got no mechanism of handling the loose firewood produced, wheras the billets stack/bundle and are then easy mechanically handled.
So still pondering.
mth
ahi l have a tran saw processor. had four 6 years and before that hakki pilke that eat it self not very strong .ring fuel wood you wont find a better british built machine
Another vote for fuelwood, the transaw is awesome, it's not a throw away machine, last forever and device is super, i think they have a used one for sale
As much as I like the look of a processor, the more I look into it the more I feel it's not right for me. I don't want to buy timber in, I just want to log up what I get for free from the arb work I do. I am now thinking a decent pto saw bench working alongside a self powered hydraulic log splitter and then perhaps a conveyor into bags/landy. Anyone else run a setup like this? Any recommendations for saw benches and log splitters? I like the look of the rock machinery venom 22 tonne splitter but I'm a bit cautious of Chinese engineering. I have no idea about saw benches. Time to trawl the forum!
We used to have a Kidd sawbench and cone splitter about thirty years ago which seemed a big improvement on the old prewar sawbench!
Both relatively lethal for loss of fingers and risk of splinters flying at you.
A lot of heavy work but it did keep you warm in the Winter.
Bought a Palax Combi off Jas Wilson second hand in 1996 for about £2500.
PTO and linkage but it had the mounting point and pulley for a motor so I bought a 3 phase and I now have the option of electric or tractor pto.
Electric is quiet and fume free and I operate it in a lean to shed with lighting.
I collect the lengths of timber with a Matbro teleporter which has an ols muck grab on the front. This will take a couple of tons of 10 foot logs from the wood to the processor and by tilting the grab and gently releasing the logs with the hydraulic grab this works for me both as a forwarder in the woods and a log deck at the Palax.
A lot of the wood is not straight, mainly Ash and Sycamore but some oak. There are some horrible shapes that would not go through the automatic feed processors and because of this they do not always fall true iunto the splitter and can fall sideways especially on shorter lengths. For this reason I disconnected the automatic trip for the splitter and use a foot operated pedal.
This video shows all the lovely straight lengths that you see on every processor video! But it does show the 10 inch diameter log (I think it will handle a bit more than this)
[ame]
[/ame]
I like the circular saw blade which with tungsten tips seems to stay sharp for ever and waltzes through most timber but the main thing is I have control of the feed speed.
When processing smaller diameter lengths that are bent sometime a nearly 90 degrees I can feed it though in a series of quick cuts without cycling the splitter which is a big time saver over the machines which need to cycle every piece. In this case I would remove the static axe if I had a lot of similar stuff to process.
I like the relatively small amount of manual labour involved so I keep warm in the Winter. I cannot imagine sitting/standing by a totally automatic processor would be much fun on a cold day. There is no lifting and it is not hard just pushing the log sideways on the rollers and pushing the log into the saw.
The conveyor takes the split timber to one ton wooden potato boxes.
A lot of this is about the cost of a processor and spending £10,000 on a fancy machine may take a long time to recover with the price of firewood and global warming.
Palax processors can be picked up for reasonable money, probably less than a saw bench/ splitter /conveyor bought separately
PALAX 600 COMBI FIRE WOOD PROCESSOR | eBay
My old machine is still going strong after 20 years with no breakdowns and not many blade sharpenings (Thank you Jas Wilsons!). I am not sure how often the chainsaw systems would need fettling by comparison.
I like the fact that the blade is about as protected from the operator as possible, certainly a massive improvement on the traditional saw bench where the operator is in line with the blade and whose fingers are inches from the blade on either side with each pass. So without a processor there is potential injury not only from the blade but also from lifting and the damage to your back.
I am an old git of pension age and try not to do any manual lifting (been there, done that with Cwt, or 50kg bags of potatoes/fertiliser/seed, I have the T-shirt and the bad back) and if I do it right the teleporter should not only bring the logs from the woods to the Palax but also the boxes to our house and plonk them right outside the door next to the wood burner.
I am afraid the sad thing about logs around here is that the hassle of selling them to the general public with all their different requirements is too much for me and the only way I can sensibly make any money is to burn them myself and save the vast utility bills that we used to have.
But there again I do not have to rely on logs as my only source of income.
  • 4 weeks later...
have a look at a splitta 400, if you are going to ring it with a chainsaw or tilt table saw then that machine will give u an abundance of great size logs, i have the older 360 it's virtually unstoppable, you will be surprised by how unfussy the machine is, as long as it fits in then it will split it even the most gnarly and dirty looking stuff seems to surrender, we cut and stack on pallets then have a day feeding it through, even 800mm dia rings which we knock in half go through, i still have to lift the rings into the machine though which is ok but when there's lots you know you've done it. i don't have an outfeed conveyor
