I made a very simple ground anchor out of two heavy pieces of flat bar with holes drilled in, laid in a v shape and joined with a shakle and secured to the ground with 2 foot long, 10mm pins driven through the holes.
I have also used 5 heavy pegs, about 20m. By 2 foot, driven into the ground in a v shape with a strop wrapped around them so they all take an equal amount of strain.
...so,could a stout chain laid in the shape of a V and secured with road pins through the links make an effective ground anchor on a paddock with no vehicular accesss and no other anchor points?.....(just hypothetical...).
Hi CHRIS are you on about a winch ground anchor if so DEVON 4x4 do some good ones but there's a member on that does professional offloading and he has some for sale thanks John
Going back to the original post, yes a length of chain or even knotted rope works just as well, but try to keep you pins in a straight line on each 'leg of the v' so no one pin is loaded any more than another. Its got me out scrapes/ wet holes many times without spending money on super kit that spends 99.9% of its time taking up usefull space. If ya flush spend away, if ya practical use ya head.
Shaun
3 pins,for instance, driven in slightly angled,(in a line) strop from top of pin to bottom of next one,etc etc,very effective, then you can add pins and strops for extra anchorage
Yep, used that one as well. If you're the sort of tit that I am, and spend a long time planning where to get stuck next, you get quite proficient at making solutions like this !!
