Bobcat Skidsteer
slippymurphy
I think what you have gained in storage capacity you will loose in time getting it out efficiently.
You could always knock out the cubicles and high step and raise the entry height at the door.
I did that for a farmer a few months back, not that big a job if you have the usual farm machinery around and your own hole to fill onsite.
  • Replies 41
Think I'll lose the metal cubicle separators so the entire length is on the base where the coos used to stand
The high step I don't mind as the wood is above ground level but the drawback is a very limited turning circle hence skidsteer.
Don t know if you've had one but I'm not the most mechanically minded and have a limit of about 5 k so second hand is way to go
Had a thought maybe a wee compact tractor with loader think that might suit me, probably easier to fix etc must be less complicated running gear ?
This cost 5k with only 50 hrs on. 24hp with loader.
Was a bit of a bargain admittedly. I resold it very quickly for a quick buck.
