with the bushnell cam you would be able to identify someone from a pic at night at 20 metres or so, the cheaper cams dont give you quite as much range, you get what you pay for, they can be quite tricky to set up to get good pics at first , but well worth getting a decent one,
The bushnell takes about a second between triggering and then taking a shot, which is where the little hikvision POE vidoe recorders score as they loop record and save 5 seconds before the trigger event.
Bushnell picture quality is far better and the discrimination of the pir is better focussed, so less false alarms.
However my bushnell display has packed up, it still takes shots but I cannot change the settings.
