I am looking for a small(ish) pressure washer and have heard that nilflisk pressure washers are a good buy.
I have been looking around and have found this model:
Nilfisk KEWE14039 - 240 Volt 140 Bar 3.9 X-Tra Pressure Washer.
Its seems to have everything you'd want in a small pressure washer.
Does anyone else have any recommendations for a similar price/sized machine or any feedback on nilflisk pressure washers or could recommend another model?
Cheers James.
Cheers James.
I have the E150 version 2.9 KW and its far superior to the works Karcher of a similar size.
The reel and the on board storage are very usefull. I have used it for many full days with no problems so far. May be P150 ?
Edited by cornish wood burner
Cheers James.
Hi JAMES we had here a small STIHL one here good old 15 years old washer thanks Jon
I had an ephiphany some time ago and came across what I call the wobbulating head. The more common name for this is the "Turbo" head and is a ceramic nozzle that makes a needle jet swirl around in circles giving the coverage of a fan but with the power of the single jet.
These heads are a must for cleaning down drives and patios as they make a run of the mill washer in to a really powerful tool!
Sorry if everybody already knows this!
I had the baby c110 for 3 yrs & was so impressed that I replaced it with the c120 which is more than enough for car cleaning & the path/patio, I will never buy any other brand of pw
It's worth looking on amazon for offers & also cleanstore.Co. uk
Anything has got to be better than the diy range Karcher!
Karchers apparently are definitely in two camps; diy units and proper ones. You need to spend quite a bit to get into the better units.
I was going to get a Nilfisk and went to a pressure washer dealer (just pressure washers and related nothing else).
Had a decent chat with him and ended up with an old recond Karcher that had the brass pump internals, far better than their later stuff.
Cheers for the help guys seems like a nilflisk is a good make to go for then.
Are there any particular models people have used that they could recommend and where i could buy one from?
