I'm not a Fabricator . .But!, (or my new log store)
difflock
If you upload them to an image hosting site (e.g. imgur.com) you can then just put links to them on here. And have as many images as you want in a post. Or, keep adding them directly to the posts, but put the first 5 images on the first post, the next 5 on the second post and so on until you've got them all up.
I think you'll find it is a drill bit from the Rotabroach mag drill which is in the same shot - the 'nail' is the centre bit which slides inside the cutting bit to activate the lubricant
Oh . Ok thanks . Learnt something there ! . :001_smile:
So 5 bes the answer.
ok
more tomorrow.
Anyway I was more than a little pleased with my fabrication skillz using nowt but a tape mesure, a steel rule, centre dab and 4.5" Angle grinder with the thin cutting discs and a crap buzzbox air cooled welder.
I found when I went to Rotobroach the 14mm dia holes for the woodbolts, that I did not have the correct size centre for the cutter.
So promptly fabricated one from a 6" nail, which worked flawlessley.
regards
marcus
