  • Replies 50
Are you sure Jon? Those Brian James /nugents/indespension ones look pretty good as well, have you asked for any opinions yet? What pick up are you gonna pull it with?
Β
Hi JOHN CAN I borrow an extra Β£800 for the James trailer 😻😻😻 IND TIPPERS ARE NOT made ind it someone Else I think Ifor are best for the money yes BRAIN MAY BE MADE better BUT I'm only going keep it 2 years max thanks Jon
Β
Β
Just pulling your leg mate, I'm glad you've made a decision!
Β
Hi JOHN DO not go there on pick up I'm putting on my old LR 110 😻😻😻for now the pick up will only be used to move dogs around and caravan thanks Jon
Β
Sounds a good solution for you John! Ive been trying to work out weather to get another 3.5t tipper truck or a tipping trailer... Lol
Β
Hi mate thanks for that the Ifor is Β£600)700 cheaper thanks Jon
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
