Got a fair bit of larch that I felled and split last Aug, although it is dry (16-18%) it still has a lot of resin in it. Is it ok to burn in a wood stove or should I leave it for another season? I have tried burning a bit and it doesn't seem to burn as clean and needs a lot more air to get it going.
MC content is from splitting and measuring (sapwood and heartwood). The wood has been cut into small logs (<4"dia) and dried in a barn for over a year now so plenty time for softwood. When you split the log you can see the resin, bark is still "super-glued" to the wood, etc. Got about 2 months supply so checking first as I have not been able to find too much info.
Assuming it was august 2014 then if its the only wood you've got burn away. If you've got other wood then personally I'd keep it till winter 2016.
As far as resin is concerned if your flue is insulated and you run a hot stove then no worries burning sticky wood. We burn a fair bit of resinous stuff and dont have any problems with tarring or smoke but thats in a stove run hot with a well insulated flue.
the perfect advice, keep it hot and you have nothing to worry about.
Do you know for a fact that its 16-18% or is that just what your meter is telling you?
