We run two Wessex trailers, one caged tipper and a 12'x6' plant for our mower. Can't fault either of them, still on original tyres. Can get a bit snakey with weight but they do have alot of rubber between the rim and road unlike our Indespension 14 x 5 which is on low profiles.
I went for the 16 ft Brian James flat bed with sides and full mesh kit. Not as strong as ifor but easier to live with and at least they bolt the axles on square. I like the steel area down ea side to strap down. I like the way the sides are split into three so it's easier for one person to put the sides on. A better thought out better finished product. Just not as tough.
Hi Steve is your a 3 axle one and what do you pull it with thanks Jon
I should mention the Brian James has rubber suspension. When it's empty it bounces around well but the Amazon has the weight to keep it under control it would not surprise me if these trailers give double cabs a hard time. My old ifor used to clack and bang but never bounced the truck around.
Hi Steve thanks that mate them AMAZON WILL PULL A HOUSE DOWN 👍Thanks Jon
