  • Replies 31
To be honest, the HS45 is only designed as a domestic use hedgecutter, hence the price, and you only get what you pay for.
The thing to note is that the blades have only half the sharp edges as most similar machines. You will see the difference in the pics. The first 3 are HS45, and the last is a Tanaka.
Hs 45 is light but its not a true double sided cutter and can be a bitch to start at times when hot but otherwise a capable machine .
Hs 81 are a excellent kit but heavy and expensive.
Ste
there not that heavy i can comfortably use mine for prolonged periods no problem.
Same here but for someone who is not to sure on what they are buying I thought I would make them aware.
Ste
[ATTACH]189399[/ATTACH]
[ATTACH]189400[/ATTACH]
[ATTACH]189402[/ATTACH]
[ATTACH]189401[/ATTACH]
This is what lets the hs45 down .
Ste
Ste
Gives a nice cut on connies though.
The HS81R doesn't give as close a clip as the HS45 as the teeth are further apart. For this there is a HS81T. But, that said, the 81R is better for hedges with broader leaves or thicker stems (such as holly and laurel).
I haven't used the husky, but I know it has better AV, so a better choice if you're cutting longer hedges
Look at all that excess thread hanging out the of the top of the nuts on that Tanaka cutter bar - why?!
