Big trailers are great we use a tt105 usually for logs as it's easy to load by hand as it is so low but it is also good for chip. Also, sadly it is not common for people do be equipped with suitable licenses for the industry they work in so finding an additional driver becomes a priority
  • Replies 54
Yes tt105 is just about the perfect arb size trailer, just had mine re sided after original sides got damaged and the high side tin sheets started to look very shabby.
Cheers will, trailer effectively double what we can remove at a time, more if we fill the back of the 130 but that means forking it out so that tends to carry the gear.
How much was it to get trailer converted? Looks v smart
Wicked! It's all about efficiency!! :):thumbup1:
1200 John which was basically a floor up rebuild but using original tailgate
Money well spent when you consider the cost of new Gray, that wont take long to claw that back. Its must hold 6 cube + .
Bob
