Need to do some work on our processor as it's got a fair bit of rust developing. It was fine until last winter when I had a lot of jobs in the cold weather and towing it around on freshly gritted roads did it power of no good. Only metal paint I have used in the past is Hammerite but really not sure this is the best option plus it will look shabby unless I can get a colour match which seems unlikely.
Would love to get it galvanised but imagine that would cost a bomb so what do you recommend :thumbup1:
  • Replies 30
Powder coat has trouble with sheared edges, common on most machines. The big give away will be the edges where the coat comes adrift after a while. Cold weather wont help it any.
Paint and coat can be colour matched, just find a paint specialist. Cellulose can be brushed or sprayed, as can 2 pack but spray will give a better finish.
The secret to good painting is better preparation.
"Powder coat has trouble with sheared edges, common on most machines. The big give away will be the edges where the coat comes adrift after a while"
Exactly what is happening so powder coat. Thanks
Touching up the affected areas is an option but think it is only a matter of time until it all needs doing. The salt water gets everywhere just is worse on some parts more than others.
Might be worth checking out Galvafroid high zinc 95% metal primer, if you can get rid of the rust and get it back to the bare metal it`s good stuff, takes real well to a blasted surface. Cheers
Think it would have to be blasted as everything gets covered in hydraulic oil from the chain.
