The guy with the old  tractor  mentioned a new  flail for  doing the encroaching hedgelines. He  already has an old topper that isn't much good I assume its  blades are blunt.
Thinking he would need an offset/side shift flail not very wide ( 100cm) as easier for the low HP and with the hammers for brambles etc?
Really he should probably just get a contractor in as has at least  60 acres.... in some place blackthorn and gorse has encroached over 25m on  other hedges theres just 1m to 5m of bramble.
Edited by Stere
5 hours ago, aspenarb said:
I bought a couple of Winton machines to go behind a small New Holland compact tractor., a stone burier and a flail mower. That little tractor has no problem powering these.
IMG_2694.thumb.JPG.0df0a28c3d5a2169e1593ddfd54d6ea7.JPGIMG_2698.thumb.JPG.281be5133088406b25b970cd34e9d4be.JPGIMG_2696.thumb.JPG.49d1785446a96a5a9c74938c5b72b7a0.JPGIMG_2696.thumb.JPG.49d1785446a96a5a9c74938c5b72b7a0.JPG
I was considering a Winton stone burier, others have told me that a 'pro' machine does a much better job. What do you reckon Bob?
PS. I didn't buy the LiuGong!
Sound bit of kit Ruben, its saved us a fortune in soils and labour on the rake.
Bob
Found they both work but the blec has a better finish and dosnt bounce as much on hard ground both benefit from the ground being well ripped before burying
Good tip, thanks.
