  • Replies 23
just change the nato hitch for a ball hitch, just undo the two bolts and replace,
Not quite as simple as that, the gas strut has to be pushed back into place which is awkward but yes, it's doable.
Its easier than you might think
Use a drift or a bolt to keep the damper in place while you swap them over:thumbup:
We have done it (the gas strut broke and had to be welded up) we used the blade of the chipper to push a socket on the end of a bar down the tube to compress the strut, when in position slip the bolt through.
Your way does sound easier!
A nato hitch is a hook ( sometimes a ball ) with a top clamp .
Ring hitches clank more when the trailer is a little tail end heavy. If the fuel tank is near the hitch keeping that full can sometimes improve things. I prefer ring hitch at least you know it's not. going to fall off if you collect a customers machine and they have worn out the coupling.
