Dunno per tonne but 1m3 roundwood produces approx 3m3 chip I think...
Thats a huge increase :001_huh:
Once you start loading large trailers does the compaction of the chip at the bottom start too reduce the volume again??
Edited by skyhuck
There are a few different ratios about I intend to weigh and measure when I get time
I have been told around 3 cube of loose chip per tonne / and 4 ish per dry tonne
Maybe someone has already done this
Not much compaction until the trailer moves. Biggest compaction we have found is in the shed when the telehandler pushes in and runs on the chip. I would guess we get up to an extra 25% weight / volume in the bottom half of the shed.
Chip for our boiler is very close to 4 cube / tonne. Wet might be 2.5 as already said.
The hundred cube walking floor trailers carry 30 ton of chip if brimmed. Thats with a mixed bag or cord and arb waste. 30 ton of cord takes up much less space.
Bob
