Thanks for the replies! to be honest i hadn't even thought about chafe - although that will definitely be a problem - so thanks for the advice! I was actually thinking the health side of things. I tend to cramp up towards the end of hotter (or more strenuous) days. And i would like to get a bit better at the longer climbs... I think its going to be a case of making the effort to get out in the evenings and weekends and smashing out a load of climbs...
Keep a cadence and chance gear to keep it the same. I like Nuun in one bottle for the salts. Helps me on cramping.
Is that like blue nun?😁
okay so bearing in mind the alps part of the trip i've started focusing more on my hill climbing stamina and technique... thank god i chose tree work - definately helps with the fitness side of things!
  • 8 months later...
I've done lands end to john o'groats, if you get the training mileage in your backside should be ok anyway, like someone said eat enough keep hydrated and you should be ok, 60km a day is only about 40 odd miles so shouldn't be too bad.
  • 3 months later...
evening! i've got a 700km trip coming up in 8 weeks from Rimini (Italy) to Munich, was just wondering if anyone here had done anything similar and what they had done to prepare for it? It's going to be spread over 2 weeks, so about 60km a day.
thanks!
How old are you?.... do you think a vsit to the doctor to get a check up might be useful if your gettin on a bit?...
As to anything else, I'd just do a couple of hours biking on a couple of weekends before you set off to prime your legs for the trip...
Believe me, you don't need to bash out the miles, just a couple of runs to put your legs through it then have em have time to heal....
Its what I did when I did my walk last year, a ten mile walk followed by a fifteen mile walk the weekend after, a week off, then 90 miles over three days..
