  • Replies 28
It looks good in the video, shame it doesn't cut a larger diameter though
Looks good and like the way the blade comes out from behind but how does it measure the length as there is no stop for the log,also any one know the price.Presumably being called a 350 it cuts up to 350mm logs .
Cheers Chris
Cheers Chris
Magic eye, laser.
Looks like it has two eyes, you can see two red dots on the stick.
The Pilke 42 has a laser eye, and its useless at producing accurate length clogs.
Never use it.
Presumably it has many and stops at the appropriate one for the log length you set.
Seems like another electronic thing to go wrong,what happens when it decides not to work the log does not stop to be cut.Shame as the rest of the machine looks good.
