Midland Road Springs will make you a custom heavy duty set with an extra leaf in, got a set made for my navara, highly recommend.
Has anyone uprated the springs on a a 3.5 ton iveco?
Can you just stick springs from a 6.5 toner on it?
A bit of a run for you but Paddington Springs in Wembley by the stadium do a drive in drive out service. They have done a few vans of mine over the years top quality service fella
They will courier the springs as well.
I got a HD front spring from them when mine snapped. It leveled the truck out nicely as well as the back sat high like a dragster!
I've got nine on the back of mine and it sits really high so much that the front is really low , so when I've a load on the front grounds out when driving around the yard , can you get spacers to raise the front ??
