2014 660 chain brake almost impossible to engage
I had the same with mine, about 2008 model.
Exhaust heat used to affect the plastic.
It sorted itself out after a month or two.
It was dangerous because the temptation was to push the brake forward with your right hand to make it engage, which is a very bad idea.
Hi mark if you ring STIHL up they will fix it on your saw they offerd me that on a old 660 like yours thanks Jon
Been fixed for years mate.
I think it was one of the first models fitted with the 'auto-self-fixing' chainbrake.
I think the manifold melted enough plastic after a while that it didn't catch any more.
The one you sold me jon did the same and developed a rubber brake handle :sly:
Had the same problem with mine, it was about 3y ago. Engineers from stijl germany came tot solve the problemen. It was due tot a faulty brake rim. They had a bas lot of brakes.
If he handle melts you have a number of issues, a plastic that melts at too low a temperature, a handle that should have steel reinforcement where it gets hot and exhaust gasses that can rise on to the handle when in a deep cut.
Having said that, I have seen some of the maintenance or lack of it :001_rolleyes: that you give your saws safety systems.
I reckon one in ten Ms200Ts I get in have a decent chain catcher in place and one in twenty actually have a clean chain brake mechanism!
The last one had trashed clutch springs but what does that matter, the chain brake stops the chain spinning - the only issue is the clutch catches the clutch drum all the time and builds up heat that melts the cover.......:thumbdown:
Had to mill out the damaged plastic with a carbide burr:001_rolleyes:
Friend of mine had the same problem the other day but only when it gets hot, it's fine when completely cold. The issue is shoddy plastic/lack of heat shielding from the exhaust. Common fault with all the 660's I've used
HI MATE A DAUL PORT MUFFLER helps loads thanks jon :thumbup:
