Hi there i have a fencing job to do that has a Hawthorne hedge that will need a good trim back some of the growth is 20 mm thick but most is 10 mm or under! I need to invest in some hedge cutters but will only use them 5-6 times a year so don't want to spend a fortune if i don't need to! Also what are the pro's and cons of single sided vs double sided cutters?
for hawthorn and beech we use a 560 with a finger bar bolted onto the side of the bar makes beech hedging and hawthorn a doodle i made the finger bar from a ryjobi hedge trimmer 2 bolts on easy peasy
Put some pics up that sounds interesting
Yeah, Granberg do a similar device, great tool, much overlooked imo,
As for hedge cutters, I prefer the double sided, I find them more versatile as they let you cut on both strokes and both directions so you have less trouble positioning yourself when working and I find it also helps with back strain as you`re far more mobile and not stuck in the same position all day, although for different jobs having both is great. cheers.
