Sorry to revive an old thread, after reading all this i'm confused.
When dismantling down the stem using your flip line for positioning and a hitchclimbr DRT secondary can't you just wrap the standing end of your DRT around the stem (few wraps) and then just clip into the running end and descend on your hitchclimber? (basically making a static anchor and then descending SRT style).
I hope that makes sense.
That's what I used to do, although I wouldn't wrap a few times just sling it round and choke, this will catch me in a fall for whatever reason but I doubt you would be able to descend quickly unless you have something to take some of the weight of your hitch/DdRT device.
  • Replies 46
If im understanding you right then that wouldnt work as your hitch wouldnt take all of your weight.
Remember in ddrt a much lower percentage of your body weight is on the hitch,much or the main percentage of your weight is on the anchor point and both ends of your rope.
This is why in srt you need a two friction devices rope wrench and a hitch to hold your weight.
I (sometimes) use an adjustable cambium saver on stems whilst choggin down.You can make your own by buying a split tail and a pulley prussik.
Thanks, yeah after posting I thought that, hence descend on a fig 8 or something and keep the hitchclimber following it down as a backup.
I'm getting way ahead of myself, just making a wishlist/pricelist of equipment to be a SE climber, 8 months to go!
So far worked out cost of saws, harness, DRT system (inc throwline), lanyard system, flipline system (tempted to just get this first and use as my secondary) and PPE.
Going off my current list, a £200-£250 a month until November will get me the essentials. I have a ton of biners,slings and stuff from my mountaineering days but am I right in thinking that I need to start logging use of all my gear for LOLER inspections? If so probably best to start over with everything.
Not factored in any rigging stuff as of yet, nearer the time I'll ask around to see just how much rigging gear people expect contracts to bring to the job.
I at first had it choked off with a single line, then had a prussic followed by a munters hitch on another carabiner next to it .. simple enough and works fine, then for re-ascent you can use ascenders or just another prussic loop for your foot moving it up, sitting/standing as you go. Though now I've got the fimbiclimb, which is great as you can adjust it to choke onto the stem nicely but still run drt. Also makes it a bit easier to change over past obstacles without having to retie everything.
In this scenario though you could just spike back up to where you were before coffee break though right? :001_smile:
My reason behind using the hitchclimber as the backup was simply because it's already set up, so literally just clip in the standing end to choke, whack through a fig 8/munters and descend for tea and biccies :thumbup:
I'm not going to even look at SRT until I get to the stage that DRT is no longer fit for purpose, and with SRT being new(ish) to the industry, that could take 20+ years :001_tongue:
I can't find anything online about the "fimbiclimb", who makes it?
Yes a fig 8 would make an acceptable bail out with the hitch just to back it up.
I don't use a flip line, I do have one but it mostly stays at home as I find them cumbersome. To start out with though it's not a bad shout and you could use it all the time not just for flipping up poles.
A good throw line set up will cost you nearly a months savings, I would probably skip that to start with.
Don't get carried away to start with, if your serious do not scrimp on a Harness TreeMotion is a solid choice.
Buying lots of kit now is a waste, I bought lots of kit then found I didn't like half of it and wasted my money.
Buy a very basic climbing kit only to start with, and a top handle saw of your own. Then add to it as your learn and understand exactly what you want.
I climb with surprisingly very little, the most expensive item in my kit bag is my throw line kit (2 faltheimer Cubes, 3 Zing it 1.75mm lines 2 throw pods and a selection of Weaver bags)
Again I doubt much of your mountaineering kit is relevant to Arb, i have a lot of mountaineering kit the only bits I use are some tape slings and toothed ascendors.
Edited by Marc
Jesus, I've seen a Stein kit for 25 bucks, guessed I'd just have to get very good at throwing :)
I don't think I'll be getting that carried away, all I need for my main system is a 35m rope as I already have the pully, biners and an eye to eye for a VT.
Harness is a big one, I've read mixed reviews about the TH5000. Cheapest on the market, which is usually a bad sign, but the reviews aren't that bad consider. Spending out £300+ on a decent treemotion would severely dent my budget, that's nearly the price of a MS150!
I really want to get my CS30,31 and chipper out the way (doing it next month) then hopefully I can put in some weekend work around my current jobs and spend that cash on tree gear!
Wiley, spending out on a good harness you will not regret providing a career in Arb is not something you regret.
I didn't realise Stein do a throw line kit for £25! Its something I suppose maybe better than nothing.
The throw line to me is my most important tool it's how I access every tree unless I can scamper up it from ground level so I am biased.
Thing is we each have our own way, as for the right way, the correct way, the only way it does not exist.
My only advice would be buy a good harness, a chainsaw, then the bare minimum like a rope, 4 carabiners, Prussic cord, HitchClimber, cambium saver and flip line.
That's all you need to start out then buy as you earn and learn.
The other bits and bobs you have for mountaineering will probably fill the gaps.
