  • Replies 22
bowline in all its variations depending on the job/rope position
have used truckers hitch for pulling trunks over with root bowls attached etc lol but always place krabs on the friction parts
timber hitch all the way
and if pulling with a vehicle use your portawrap with a short sling or rope to towball much easier to undo and less damage to rope
If mounted to a krab first; i'd go with a triple noose/scaffold/anchor to self to form eye. i'd go that way so if it jammed i could work it off krab and free up. Much stronger than Bowline(sheetbend to self to form eye; but also changes the hitch to a half hitch); and probably take more dynamic forces. If i was afraid of not being able to free it up; i'd go with DBY. Note, Double ring(not double eye) bowlines are stronger and absorb more dynamic forces(i think); but; due to the eye pulling at a higher point; it has more leverage to invert the works into a slip knot and capsize, so must be dressed well; especially in stiffer lines.
If tying to a perpendicular pull on a spar; i'd go with a binding knot. This is kinda like a constrictor; the last tuck goes in the same place; but the 2nd to last goes over, not under(so you don't quite make a clove first). Almost same security, with no jamming; a real favorite of mine. On an inline/lengthwise pull on same; i'd precede whatever finish with a half hitch; and try to dog each of these rings somehow. (Note that in the ABoK bible {everyone has one wirte?} that lengthwise and perpendiucalr pulls are 2 seperate and distinct chapters; right nest to each other) The finish might be a running DBY. Note the Double Bowline (2 rings to lock, not 2 eyes) is about 5% stronger than a regular Bowline(which is about 65% tensile efficiency). But, a running Bowline determines it's strength differently; and can vary by teepee.
Sorry if, once again, so many answers; but for me it is dependent on other variables in equation/ know static answer. Also, i exercise the decisions in the art to not only accomplish the task, but be more fluent with it; and see more things in it. Kinda a 'you get out of it what you put into it deal'. When there is time or folks to share with; i invert the deal; to make the art the target, and the task the secondary payoff; rather than the other way around. Perhaps i'm jest lysdexic like that. But, many times the real payoff/ what i really carried with me to the next day after the check was spent; is/was what i L-earned. i've all ways about blown whatever monie$ somehow; so this other has been my $avings account somehow; and more of what i had to 'loan' to bail someone else out.
Okay; it is safe to come out; i'm off the soapbox for again...
edit; timber is okay; especially on spar with bitters finishing upabout 7o'clock from the initial pull of 12 o'clock. Killick/timber precedd by half hitch is more secure and better on inline pull on load/device.
