what grease do you use
simonm
Any good quality Lithium based grease will do. I use JCB HP grease mainly because its easy to get hold of. I've also been known to use a graphite grease but that is thick sticky stuff, that normally goes in hard to reach places as it takes a long time to come out.
Graphite grease is not designed for high spinning bearings!
It primary purpose is for high load sliding surface contact lubricant
Hence the thick tacky constancy
This would be a more suitable grease
EPK2 lithium based grease which has a high load (Extreme Pressure) high melting point - perfect for high spinning bearings
