Not really - it's pretty rustic grade stock, and somehow I made a catastrophic miscalculation and it's only 685m, not just over 4000. :001_huh: Friday afternoon quoting after spending all day wrestling with stupid little cherry logs cutting them for a customer.
don't you just love the customers who bring you firewood to mill, I had somebody turn up with some yew bits that were only 24" long a few weeks back....
As for larch, go for it , am currently machining up cladding that I have cut and dried ,9" x 1", approx. 800mts of it, it seems endless...... oh for a big four sided planer!
Im curently milling 116 larch logs for a log cabin build, all in the 10-12 inch range, great stuff to work with, when used outside larch will last a very long time with no other treatments
The larch is actually my stock, but it's only for planters, so it doesn't need to be top notch.
We've got a four side planer which has seen a lot of use in recent months for T&G cladding, but I'm particularly excited about the prospect of an edger, for resawing those first waney edged boards you cut as you square your way into a cant. Resawing them is a major pain and an edger might be a touch more wasteful, but worth it in the end.
Hey J,
you ahve a logosol i think (like me) has the cladding been using the jibs on the top or bottom head or just side cutters (obviously depends on the profile) I have ran out fair bit of T&G and vee groove T&G but never used any of the top or bottom profiles, just wondered if you had and what they are like.
Thanks, John
Absolutely Yes!
We're building a barn with Larch at the moment.
Not sure if you've seen it but there was a Channel 4 Grand Designs house in Monmouthshire (near Tintern Abbey) that used Larch and they were required to have it strength tested (because it was a bit of an unknown).
The results came back way stronger than other wood varieties.
Cheers, Steve
Hey J,
Thanks, John
I've been getting my head around a PH260 over the last year, but we've just moved and getting it set up in a new workshop. The top and bottom knives are quite clever and straightforward, I'll do a bit of a thread when the power and dust extraction are on. W
