  • Replies 24
Depends on what you want it for ? Silky do two good ones , the ' Gomtaro ' which has a straight blade will do most small to medium size stuff or the ' Zubat ' which has a curved blade and will cut bigger and faster with less effort but for smaller shrubs may not fit as neatly into the crotch . Probably all the retailers on this site sell them .
If you search you will find a couple of older threads covering your question extensively.....but for the record if you choose a "Silky Nakanoto 60" (straight) you will have the finest hand cutting tool ever created....Welcome to Arbtalkland:)
Always have my zubat with me up a tree
Same as, I use a zubat up the tree too. The hooked end comes in handy now and then. I often reduce trees with it. Makes a change from lugging a chainsaw round with you. 👍
I've swapped from regularly using a gomataro to the tsurgi it's great for reductions thinning etc. I thought it maybe a little flimsy but it's not by far the best silky I've used to date.
I'm a lefty so the nakanoto not great for me as its holder is suited for right handed. Same with curved saws as well I've used them both perhaps it was the hindrance of struggling to put the blade away but neither of them were as good for me.
