Would imagine it's fine as long as they're not case hardened.
Regards,
Steve.
I think he's after angles/tips.
Never considered they might be case hardened!
I usually use a flat file, but have run a bench grinder over them when they've been really bad.
Make sure you keep the right angles, they'll not work properly if you do something odd to them.
I usually do the underside face towards the point, then tidy any burrs on the top two faces, making sure to keep the centre point aligned with the spine of the gaff.
  • 1 year later...
