cabstar timber truck
combined tree services
Just a thought Dave, to overcome the over loading issue, is it possible to mount the hiab in a rear corner? I realise it might be in the way from time to time, but if you no longer have it as a tipper, maybe not too bad.
Main reason for rear mounting is you can also tow a trailer and load it with the hiab, therefore spreading a greater load between the two. Also better positioning for lifting logs off narrow drives etc.
  • Replies 80
yeah that is an idea i will look into , the good thing is i have already taken the tipper off soi can pretty muct mount it wherever , i may well mount it to the rear and load a trailer as well :001_smile:
There was a member on here called "Igottacabstar", he was barred....
...as long as your wife isn't a lawyer and you dont live in a £1m house you are ok
And own a number of houses and a gift shop and be a UFC champion.
Actually I have heard he can rebuild Uniomog gearboxes blindfolded underwater.
