Have around 50 ton of big butts lying in my yard ranging from 3-5 foot diameter. Currently using a 461 on a 25" bar. Did have a 064 but got rid as the vibes were killing my hands. Should I be thinking of going up a size of saw to a 661 or 390/5 or stick with what I've got? I have a fairly regular supply of this size wood. Any comments would be appreciated, thanks.
  • Replies 69
Your stihl will manage a bigger bar, cheaper as a new saw! Youve got 76cc(?) there, i run 28inch bar on 68cc no problem so id be happy to go upto 30inches.
Unless youve some cash burning a hole in your pocket, and an itch to scratch... in that case get a bigger saw!
That's pretty big wood got to say I would be tempted with an 880 3120 in that size timber.
Most of it is closer to the 3ft but there is a good number of 5ft oak. I plan on keeping the 461 as its a lovely saw but was thinking 661 390/5 would be more useable than the 880 3120.
Get a 660 I would go for an older one with the screw caps if you can find one I got a brand new 2009 model in early 2013. I'm in the yard now cutting up over size. We run outs on a 30 and tackle pretty much anything.
880 is a bit over kill for firewood IMO big old lump to be wielding it will make your arm ache.
There is a huge difference between the 064 and the 660 in terms of vibrations. My old 064 I could cope with for about 15 minutes and my hands would be ringing. With the 660 I could use it all day and not have a problem.
Definitely won't be getting an 880! A 660/1 would be a big investment considering I have a full time job and the firewood is a rather time consuming second job. Have to be sure that it would be justifiable
The trouble with cutting up big butts with a big bar is, if you hit something you've a hell of a lot of sharpening to do. Stick with 28" or 30" bar, whichever model of saw you use.
