  • Replies 67
What are the benefits of an 8 tooth sprocket over the stock item?
In fresh air ...faster chain speed . Buried deep in the wood ...don't lean on it too hard as you have sacrificed a little of the torque by upping the gearing . An 8 pin sprocket still allows you to use a standard chain loop for your given bar size . If you go to a 9 pin you need to add another driver to the loop . I find the 560 that I have sufficiently strong and grunty to run 18" bar .325 chain driven by an 8 pin . It is modded slightly though . Hope that explains it . :001_smile:
All this talk of using an 8 pin sprocket makes me curious... I'm currently running standard 7 pin on .325
Is this the correct 8 pin sprocket for my 560?
.325"-SMALL7-8 Replaceable Rim - 11891 - New Saw Chains
Thought I'd give it a shot and if nothing else i've got another spare.:thumbup1:
7 is what comes as standard ( too conservative IMO ) 8 is good . ( standard chain loop ) 9( is quicker ( non standard chain loop ) but will sacrifice torque .
Edited by Stubby
It's actually 7 for one reason only, PPE! 8t means you need class 2 trousers, 9 would be class 3, but trousers aren't made to that spec
