Anybody filled the bit of time off with little making or mending projects they'd like to share picks off.
Mine to start, made this as a present.for a friend who runs forest school groups and sometimes struggle to get permission to have an open fire, now it's contained.
Also made a hot plate to sit on top but forgot to take pictures of that and a taller flu to sit over the little chimney that along with the legs fit inside fir transport.
Very good .............i did something very similar years ago but i made a removable ash plate so has not too burn bottom out , i weld 4 nuts to each corner of the ash plate to keep off the base and drill a load of large holes in plate .
Ste
Cheep way of doing that is fill bottom with sand to keep heat away from the base and stop it burning the mettle.
Chance would be a fine thing Paul!! ;-)
I am as daft as I look just occasionally get a good idea :-P
my christmas project was building the mulcher attachment for our mini skid steer its been out and tested and it works pretty good i need to do a video its fitted with a gx390 and i wasn't sure how much power was needed but 13hp seems to be ok
