Condensation trap/moisture removal ???
skyhuck
  • Replies 44
The container is 35ft long, but there is a movable insulated partition that can be used to shorten the internal area being heated. I'm using a 90KW wood gasification boiler to run the 30KW blower, this boiler also heats my home.
I'm only just started to play with it, so don't know how long it will take to dry different sized loads.
I take it you mean a 30kW(thermal) fan coil unit which is supplied by the boiler with hot water and then the hot air is circulated?
I suppose you don't have underfloor heating at home?
Ah ok, I just had visions of using dry wood to dry wet wood and my head getting in a spin. I assumed it must be cost effective etc etc to do this although I hadn't considered it would heat your home too :thumbup1:
Can anyone enlighten me about the optimum operating temp in log drying kilns please
I've assumed the hotter the better, cracking and distortion is not an issue, unlike furniture timber kilns, so I'm just trying to get the water out ASAP.
I could well be wrong :001_smile:
