  • Replies 44
Having seen the pics, plenty do.
Whats wrong with being cautious. How many on here have been broken into and had there kit stolen. My major defence is that I live in the middle of nowhere so why should I give out my location to potential thieves. How many times on this forum has an op posted up a picture only to find the piece of equipment in the backgound discussed. Security in this day and age is not just about physical security.
Absolutely nothing wrong with caution.
I would be interested in knowing which pictures on here have position in their exif data, especially any of my own!
As it was I who first asked for a pic...just want to say that I completely get John's wish for security & there were similar pics on youtube. Anyway back on thread & it looks a cracking use of sawdust.
Would it be a viable proposition to use a sawdust/chip burner to run a crude firewood kiln.
why not? It's a source of clean heat and all you need is the heat to supply the latent heat to change moisture to vapour and a means of circulating it.
Air drying is probably the mos economical but it becomes a toss up between cashflow and cost of dry storage verses capital cost and energy use for the dryer.
To dry from green 50% to oven dry will cost about 30% again of the energy in the dried wood plus running circulation but it's not worth going below 20% as dry wood picks up water from the atmosphere.
We ran a number of experiments on various scenarios when designing a dryer for our client and one which showed promise was a directly fired batch sequential one that dried in 3 days but wasn't adopted because it would have been too costly to certify the burner, which appeared clean and burning with about 30ppm CO.
No problem at all. Using sawdust/chip burners is common practice in Europe for running bread ovens the only complications start when you try to claim RHI on such tried and tested technology.
PM me with your email address and I will send you some pictures of my set up or if passing your quite welcome to drop in for a look.
