Sawdust burners are terrific, made one out of a large propane tank last year.
Would be ideal for something like a glass house or polytunnel as above, takes a minute or two to get loaded up certainly but then you just leave it.
Very good also for a workshop or anywhere just needing a constant background heat.
  • Replies 44
Are you guys using the barrel style with a former tube to make a central chimney or any other styles in use? Seems pretty perfect if you've got low m/c sawdust.. Have you tried using chip in a burner like that or does it not hold together well enough, maybe a mix?
My sawdust burner I made from 2 x 45 gall drums and an industrial air filter with the paper filter burnt away to leave a mesh cylinder laid on its side which I fill with sawdust. Light at the front and it will burn its way through to the back. The mesh acting like a davy lamp.
Will burn chip just as good as sawdust.
  renewablejohn said:
Sorry dont do pics anymore since I found out location is encrypted in photo. Got to much equipment to lose.
There is a setting in iPhone/pad to switch location tagging off, I'm sure android will have similar.
Sawdust stoves are great. I use one to heat my green house in the spring when I produce the seedlings for my garden. They give good heat for a long period and burn sawdust and chips and I even use to mix some wood pieces to keep for a longer time when needed.
I had a borrowed smaller stove but i intend to make one from a 200 L barrow. I use any kind of sawdust but the hardwood is better.
Read more
