Unless you catagorically know there is a blockage in there and clear evidence of sludge in the oil pan, don't flush. Better to run a cheapo CI oil for <1000 miles and then do the O&F again with better.
Above is absolutely right about oil filler and dipstick - allows air flow down. I've sometimes cranked it over with filter off to spit out the glut in there but obv don't run it!
Nope I don't recommend it unless is been used at every oil change, if it's bad I would remove the sump clean it out remove the oil pick up pipe clean it out or replace it's (some are a bugger to proper clear out) then put fresh oil in it and run it for a few months/miles and then flush it-----just depends on how bad it is:001_tt2:
I'm on wid dropping the oil on my entec 150 and just heard people doing it! Will prob just put new filter on and put the fresh oil in!
👍👍 will be fine
What was the problem?
I was to lazy to drop the sump and clean the pick up filter.
It's been fine since 2 years ago.
Did the same last oil change on the chipper as well.
