I'm after some advice I know the figures can only be a rough guide but...
I'm wondering how much wood it would take to run an 8kw stove through winter
Open to hardwood / softwood options
Burning for about 8-10 hrs a day
Cheers
Cheers
Tooo many variables . How efficient is your stove ( Burley , 89% efficiency , cheapo Chinese stove 38% efficiency ) , how dry is your wood etc etc etc to give an accurate punt at it :001_smile:
Cheers
HI LIOYD it all down what wood and how good the stove if cheap one they use loads of wood mate what make of stove is yours then thanks jon :thumbup:
Cheers
I think 2 logs per hour at 1.8kg a piece, which is about thirty kg a day, a goodish log basket, so between 2 and 3 tonnes
3 bed 1930s few draughts still some single glazing but slowly working around double glazing
I know this can only be a rough estimate but gives me a clue what I'll need over the next few months
HI LIOYD how much did you use last year then and what the make of stove thanks hard wood soft do you use thanks jon :thumbup:
